Home > General > Alarm Issue
Ninja
United Kingdom 2007 Range Rover SE TDV8 Rimini Red
Alarm Issue
I have owned a 07 Vogue SE diesel for the last 18 months. It has not missed a beat and I am very pleased with it.
I do however have one issue with it. For about the last couple of months the alarm goes off each day between 8.00 to 8.15am. It is never before or after this period and it never goes off at any other time. I am just wondering if any of you wise people have any idea what is causing it?
Post #72333 14th Jul 2011 9:23am
Rolo
United Kingdom 2012 Range Rover Vogue SE TDV8 Orkney Grey
is there a lorry or other vehicle going past it (if it's parked on the road) that is activating the tilt switch or glass tamper ?
Some vibrations / movement from passing vehicles can set off alarms.
or some annoying kid gives it a whack as they go past on the way to school /work ?
Post #72337 14th Jul 2011 11:01am
Ninja
No it is not parked near a road as we live on a Farm. No animals or children go near it. It is almost as if it is pre set to go off at that time!!!!
Post #72340 14th Jul 2011 11:25am
member supershuttle had a similar problem, the suggestion was to disable the bonnet switch and this seems to have solved the problem..
Post #72344 14th Jul 2011 11:57am
Ninja
Yes I read that but why would it go off at the same time each day??
Post #72346 14th Jul 2011 12:01pm
ric355
Check to see if auxiliary heating or ventilation is programmed to come on at that time?
Post #72347 14th Jul 2011 12:08pm
its a process of elimination ninja, got to start somewhere.. Wink
Post #72348 14th Jul 2011 12:13pm
Ninja
ric355 I will have a look later but I cannot remeber setting it and I doubt I could work out how to do it !!!
Post #72352 14th Jul 2011 12:50pm
johnson1
Pre-heat and vent has been known to create an issues due to the air movement inside.
Post #72372 14th Jul 2011 2:42pm
supershuttle
Disconnect the bonnet switch first it's quick and easy, if that cures things you have found your problem and can either replace or service/adjust as I did, if not look elsewhere.
I was looking for air movement in the car, pre-heater coming on, steering wheel moving, suspension pump activating. I never thought it could be the bonnet switch until scarey suggested it - and it was! Geoff
Post #72439 14th Jul 2011 9:36pm
Ninja
Thank Supershuttle.
I will give it a go tomorrow.
Post #72474 15th Jul 2011 8:26am
Ninja
Problem Solved Very Happy
Got a Friend to look at the bonnet switch and he cleaned it. This was on Saturday and it has not gone off since. Still cant work out why it went off at the same time each but hopefully all well now. Thanks for everyones help.
Post #72940 19th Jul 2011 11:48am
result... Thumbs Up
Post #72966 19th Jul 2011 1:01pm
Rolo
good news !
and I remember someone who said this forum never gives helpful advice so they left....... Rolling with laughter
Post #72971 19th Jul 2011 2:29pm
Googsy
I WANT YOU TO LOVE ME ? Sheep Sheep Sheep
Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #72973 19th Jul 2011 3:15pm
