![]() | Home > Technical (L322) > Please help me! 2012 Westminster |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1310 ![]() ![]() ![]() |
What mph does it start doing it? How many miles has it done.
Ryanc Member Since: 16 Feb 2025 Location: Kent Posts: 7 ![]() ![]() ![]() |
Hi thanks for replying.
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 767 ![]() ![]() ![]() |
Silly question, have you checked tyres and wheels for buckles? I had nasty vibration turned out the inside of one tyre had a bulge, 2 new tyres later vibration gone. |
Thanks,
Is it worth swapping the front wheels to the back and see what happens? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2664 ![]() ![]() |
Does the vibration increase with road speed or engine speed or engine load, indicating drive-line or engine / torque converter issue?
I’ve tried swapping wheels around but still get the vibration.
Has the transfer case oil been checked? L405 D350 SE Carpathian Grey D5 19" rims |
Had the car up in the air today.
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 125 ![]() ![]() |
Sounds like you're doing a great job replacing parts. It will be great once you nail it down. Random one, there aren't any wheel spacers on it are there? Even hub-centric ones can incite vibrations through the car.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 525 ![]() ![]() ![]() |
maybe wheel bearing ? |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 178 ![]() ![]() ![]() |
My Wife's P38 had a similar problem which turned out to be the viscous Fan. Does the vibration happen when reving the engine in neutral? Something else to eliminate. 🙂 |
