Hi Vincent, I don't have much to offer you, buut have a similar issue. 2010 5.0 N/A. My 5th L322, no trouble codes present. 215k miles
I had been chasing some coolant loss and have swapped a couple of pipes, the coolant distribution valves and the water pump, which, fingers crossed, seems to have addressed the coolant loss, but my heater still behaves strangely.
Only in the drivers corner of the car though. Passenger front, passenger rear, drivers rear behave normally, but drivers side front will deliver heat normally for a short while after startup, then go completely cold, unless I crank drivers side heat up to very maximum, when I get some, but low, heat. Anything less than full on the dial is ambient coold.
Following, hopefully we can get some help!
