Home > Maintenance & Mods (L322) > steering column adjustment motor fails to shut off
Varks74
Anyone had an issue with their steering column adjustment motor? when i take the key out of the ignition the column sometimes moves up and in as it should but then the motor continues to run and carries on unless i touch the control lever,
hopefully there is a reset procedure someone knows about that i can use,
Post #715807 9th Apr 2025 8:10am
