Home > Maintenance & Mods (L405) > L405 potential problem ahead?
BasherBishop
Hi guys. I've recently bought a 65 plate RR 4.4SDV8 Autobiography 90k miles on the clock. After parking it overnight with the suspension in normal setting. Sometimes the front suspension is on its lowest setting in the morning!
Is there a nightmare awaiting me?
Any information will be great.
Many thanks
Anton
Post #715709 7th Apr 2025 2:10pm
Sounds like a leak from the airbags, raise it to off road height, you may be able to hear it.... with the engine off obviously...!! Pete
Post #715714 7th Apr 2025 2:41pm
Oh, and it's a "now" problem, the compressor will be working overtime to keep air in the system, leave it too long and you will need a new one...!! Pete
Post #715715 7th Apr 2025 2:50pm
BasherBishop
Thanks for the sound advice! I'm now on the case.
Post #715719 7th Apr 2025 3:30pm
Dolphinboy
I have almost the same car and there is an option out have it automatically lower to access mode upon parking.
Make sure it's not this happening first!
Post #715733 7th Apr 2025 8:05pm
BasherBishop
I'm not convinced it's that because it's only the front that lowers. I will check though!
Thanks.
Post #715749 8th Apr 2025 5:19am
alaska1993
Romania 2016 Range Rover Autobiography SDV8 Santorini Black
I just bought my first Range Rover, an L405 and it was set to lower when the car was in park. It drove me nuts. I was able to disable that feature.
Post #715779 8th Apr 2025 8:06pm
Gremlin500
Ummmm, there are 2 schools of thought on this:
One is, disabling “Access Height” (as it’s called) saves wear & tear on suspension airbags, by stopping them continually being moved up & down.
The other is, enabling Access Height saves wear & tear on the airbags being concentrated in one place, by continually being moved up and down.
Take your pick! Rolling with laughter Rolling with laughter Rolling with laughter
Gremlins’ expert advice? Sometimes do both, and sometimes do neither! Thumbs Up Laughing
You will notice the front first, because you’re staring at the bonnet (hood) and by the time you’ve watched that in an almost trance-like state, you’ll have completely missed what your rear end was doing! Shocked Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #715789 8th Apr 2025 11:38pm
I’ve got auto access off on my 405 and D5. Drives me up the wall. I leave it off and make sure to raise and lower the suspension often so as to give the bags and compressor something to do!
Does sound like a leak for the OP, hopefully you can locate it, ages back I had the same thing on my 322 it was a front bag which had sprung a leak in the folds. There is nothing that can't be fixed with a hammer😜😜
Post #715790 8th Apr 2025 11:43pm
BasherBishop
Well Gremlin. After reading your post , things are much clearer to me now, it makes so much sense. Now I'm in a trance like state:)
Post #715794 9th Apr 2025 4:21am
BasherBishop
I think I will turn auto access height off too, it drives me nuts, if I had one airbag leaking? Would both sides lower? Because both my front wheels lower when this happens.
Post #715795 9th Apr 2025 4:25am
you parked on a slope? sometimes the FF will try and level .. ... - .- -.
Post #715804 9th Apr 2025 8:05am
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I think this is nonsense. When I got my P38 in 2009 at 65K miles, I changed all four airbags. They are still on there, the odometer reads 200,000 miles. They don't leak.
As far as I am concerned, they are fit and forget.
The 99% of wear will occur as the suspension goes up and down at normal height, and there's nothing you can do about that apart from not drive it!
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #715808 9th Apr 2025 8:12am
BasherBishop
Potential problem ahead? Solved!
I had a diagnosis for my RR today, it's a predictable RR Gremlin Smile.
No airbags leaking.
No compressor issue.
Thanks for your advice chaps, I'm sure I will return soon with another conundrum.
Over and out!
Anton
Post #715915 10th Apr 2025 6:00pm
