Home > In Car Electronics (L322) > MOST and mirrors issue
Varks74
Hi all, new to the group, not new to LR though as i have owned a D3 for a few years,
I have just purchased a 2007 TDV8 Vogue SE Overfinch in Java black,
I bought it with an ICE issue and an issue with both mirrors,
The touch screen is dead, no orange light, no LR screen logo, someone has added an aftermarket video unit into the rear compartment at some point which does have power to it, i have checked the fibre optic plugs in the rear and none have any light, so i have purchased a bypass loop and will go through the boxes trying that later today, starting with the bluetooth module, as that seems to be the usual suspect, i will report back with the results from that,
The mirror issue i haven't managed to delve into as yet although seeing as it is effecting both mirrors and having checked all the fuses, i have ordered a replacement switch panel for the top of the drivers door, in the hope that this sorts the issue, that should be here today or tomorrow, i cant imagine both mirrors have failed at the same time,
What i am struggling to find though is information on all of the relays, i have found some info listed but can't find a definitive list anywhere,
I am hoping to get my code reader back from a mate i lent it to later today, so will see if there are any fault codes saved for the problem areas,
any help with any of the issues will be greatly received,
Cheers all, I have added a pic of the new beast Thumbs Up
Post #715465 3rd Apr 2025 9:42am
Varks74
small update, I swapped out the fuse box as there was tell tail signs of water ingress, think it was old but it was there none the less, however that didn't make any difference, i did then swap out the switch panel on the drivers door, i now have a drivers mirror glass that moves, (half a thumbs up) the passenger mirror is still dead and neither mirror folds,
Next time i have the glove box out, which will be in the next few days to swap out the IHU, i will take a look at the fold back module, which i believe is just a relay that sits near the A pillar on the passenger side behind the dash, i will see what voltage, if any, i have there, fingers crossed the new IHU allows life back into my MOST system, i've been chasing this fault for several weeks,
all it leaves for me to do then is find a Gap iid tool so i can turn off the easy access setting on the steering column, as it runs on for ages after the steering column stops moving,
then i can start on the fluid changes lol, good job i love driving this!!!!!
Post #715887 10th Apr 2025 8:47am
