![]() | Home > Technical (L322) > Flat Battery - Rear lights remain on whilst charging. |
chrisnj Member Since: 21 Aug 2017 Location: Surrey / North Somerset / Florida Posts: 60 ![]() ![]() ![]() |
Does anyone know anythign about this or can the OP give a follow up on what they did next?
Paul H Member Since: 17 Oct 2023 Location: coventry Posts: 79 ![]() ![]() ![]() |
To be honest, not a clue!
Thanks Paul - will leave it on charge for all of today and see if it recharges, if not will sort out getting a new battery tomorrow and go from there - hopefully its just a failing battery like yours and not something more complicated! ----------- Current Garage --------------------
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 117 ![]() ![]() ![]() |
Did either of you initialise the Battery Maintenance System (BMS) when changing the battery ? Worth a google if you’re not familiar with it. |
That’s a valid point. I did when replacing the battery but wonder if it needed it when charging from flat? 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea! |
Something weird going on. Well it is FFRR I suppose |
