Home > Technical (L322) > Code p0622 I need help
princeley@ymail.com
South Africa 2006 Range Rover Supercharged 4.2 SC V8 Barolo Black
Hello everyone I hope all you are fine I am New in this platform I need your Help please guys my range rover l322 2006 has problems with charging system code p0622 I change new alternator but the code still there today I try to trace the the f terminal connector wire from the alternator to pcm I only get one continuity wire white and green color but my connector have 3 pins so I need someone to help me with alternator wiring diagram
Post #715132 29th Mar 2025 7:39pm
Welcome,
Download the workshop manual from the WIKI (link at top of page under fullfatrr.com)
It may have what you need... Thumbs Up Pete
Post #715146 29th Mar 2025 9:26pm
princeley@ymail.com
Hello my Boss Thanks alot God bless you more I got it as I wanted Thank you
Post #715155 29th Mar 2025 11:16pm
princeley@ymail.com
Thank you very much rangerover family my problem was solved today after I get the wiring diagram the problem was the sense wire from the alternator it was disconnected after I fixed the battery light was off I'm so happy
Post #715211 30th Mar 2025 7:23pm
