Home > Maintenance & Mods (L322) > DIY smoke detection
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
DIY smoke detection
Hi
I prefer to do something myself where possible and am currently trying to identify the cause of restricted performance at higher revs.
I had a leak where the air intake joins the throttle body which is now fixed thanks 100% to FFRR.
I am going to replace the MAP and both MAF sensors, at 13 years old they have served the car well.
I can buy a very well rated smoke test machine on Amazon for £140 which is likely similar to what it would cost me for one test at a garage.
Has anyone here done their own smoke tests and if so could you be kind enough to point a beginner in the right direction.
I have zero oil usage, zero smoke and tye car purrs so I am confident I have a air leak somewhere, a bad sensor or a sticking valve of some sort.
Thanks 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #715113 29th Mar 2025 3:25pm
Merchy
If you type in the following for the internet..... 2012 TDV8 l322 smoke test you tube ... there are several videos that may help you Thumbs Up
Post #715118 29th Mar 2025 6:22pm
Gsxr1250dave
I have something similar to this which connects to my air compressor tank .
https://www.ebay.co.uk/itm/256784976268?mk...media=COPY
Post #715131 29th Mar 2025 7:36pm
dhallworth
I made a smoke tester from some drain pipe fittings which uses 12v and an airline from our compressor.
I'll try and find some pictures of it later. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #715137 29th Mar 2025 8:19pm
Eastsoutheast
Thanks for the replies, appreciated. I would like a steer on where best to attach the detector from anyone who has done it on the 4.4 tdv8. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #715141 29th Mar 2025 9:09pm
