![]() | Home > Technical (L322) > Engine mounts replaced 4.4 tdv8 |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 292 ![]() ![]() ![]() |
Not heard of those type of issues before. Interested to hear how the test drive goes. TDV8 4.4 2012 |
s.m. Member Since: 21 Feb 2016 Location: Sarajevo Posts: 8 ![]() ![]() |
After test drive, the resonance is almost gone. It has only about 1100 rpm. There is slight vibration under the left foot.
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 13 ![]() ![]() ![]() |
I also replaced the two engine mounts on my 4.4 TDV8. I also have the vibrations under the left foot at 1100 rpm. I would also like to replace the rear gearbox mount - but the original is not available. |
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 33 ![]() ![]() ![]() |
Hello, i have the same vibration issue on a 3.6 tdv8, more than 230k km on the original, 15 years old engine mounts will book my car in to get this fixed. For the rest if the vibration I recommend to replace the gearbox mount brackets as well, freaking espensive the 4 piece of rubber, but can potentionally solve the remaining vibration issue.
Hello RRfranz, Pal,
I will now try to see and test the engine mounts. Vehicle sztationary, engine on, stand on the brakes, put it into drive and press a bit on the gas to see how much the torque would rotate the engine on the mounts. So take it on the camera to see how the engine moves with the bonnet open while performing above in stationary. The engine mounts are vacum controlled sp it can also be, that a hose is leaking and the mounts are not controlled correctly…
