Home > Maintenance & Mods (L405) > Front Lower Arms
Jamers
Front Lower Arms
I'm looking to replace my front lower arms, does anyone have suggestions / recommended suppliers and/or brands for them?
I've noticed most only replace the lower arms, is it worth replacing the top arm / bushing while doing the lower arms?
Post #714568 21st Mar 2025 12:40pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
Lemforder are a decent brand they might even be OEM (not sure on that but someone will know)
I don’t think the top bushes will need doing just because the lower arms do, however while you are in there it would do no harm to do it all. That’s generally my philosophy and the whole job is still cheaper than the garage doing just the arms.
I paid a specialist independent £760 to have the front lower arms done using genuine parts, if you wanted a guide to costs.
Post #714588 21st Mar 2025 8:33pm
Gremlin500
Yes Alex is right, Lemforder are the OEM supplier, I did mine a few years ago, made an immediate difference to the wooliness around mni roundabouts etc.
You may need one of THESE:
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #714595 21st Mar 2025 11:58pm
evotime
I bought mine from ebay. Had the car 2 years and no issues. I did not use a joint splitter. Good crack with a hammer and they came out easy enough.
Plan for an hour a side. If its your fist time prob a 3 hour job. Easy enough.
I think the top ones are a mare to do. The bottom ones stopped an annoying thud I had and really tightened up the steering. Deffo worth doing X5 40d
Post #714623 22nd Mar 2025 4:03pm
Gremlin500
Mine were a total b*tch, no amount of hammering/heating worked.
The splitter did them (after a week with no car) in seconds.
Sods’ Law says if you don’t have the splitter………………. Whistle “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #714625 22nd Mar 2025 4:10pm
evotime
Aye, no way of knowing. Sods laws is never far away Laughing X5 40d
Post #714629 22nd Mar 2025 5:18pm
Mikey
I remember my first set, heard the stories about damaged hubs and and generally being a nightmare. Waited nearly a month for the hydraulic tool to release them from the hub
Undone the lower nuts and both sides fell out Rolling with laughter
But on the other hand, we've experienced those nightmares too
Post #714632 22nd Mar 2025 5:36pm
