![]() | Home > Maintenance & Mods (L322) > Suspension message 30 MPH |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8514 ![]() ![]() ![]() |
First thing to do is plug in your IID and follow the attached to read any faults, then I always export them via email to myself, then clear the codes and see what happens... |
JonnyCJ Member Since: 12 Mar 2024 Location: Wirral Posts: 132 ![]() ![]() ![]() |
Thanks Pete - that export function is handy will have play. |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 125 ![]() ![]() ![]() |
I had that exact issue last month and the bouncy bouncy ride home was a little disconcerting to say the least |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
I recently had exactly the same as in NobbyC's post, I had to lift the car to off road height to hear an air leak. I had to go from normal to off road height several times before I heard the air leak. |
Thanks chaps - one to look at when the crankshaft oil seal is sorted. |
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 118 ![]() ![]() |
Could be as simple as a height sensor.
Thanks Goldstar - it’s in the garage at the moment having a few pulleys and tensioner replaced, but will get them to interrogate the ride height sensors.
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 334 ![]() ![]() |
deleted by author 2012 L322 4.4 TDV8 AB low mileage - a peach
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
Had the same issue but a different fault with my AMK compressor which I think you have.
Popped into Bell Automotive this morning to get them to have a look at the suspension issue. It only occurs at 45mph+ and Graham said - "ah - dynamic response system, let's have a look at your wiring"
I could have been chasing my tail for ages on this, so looks like a hopefully simple and non expensive fix. I'm on hols on Sunday, so they're going to take it in and sort the wiring, as well as giving the car a thorough clean underneath, followed by Fertan rust treatment for any rusty bits and then Dynax UC for the exposed bits and Dynax S50 for any cavities. There's also a second oil leak towards the rear of the engine to be looked at, so hopefully I'll come back from hols with it all spic and span. |
Tidied up the wiring and soldered some clean, neat connections to replace the dodgy repair previously carried out. Used full length heat shrink over the area and a grommet into the top of the suspension turret.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
No expert, but I think the “max 30mph “ type suspension fault relates to air springs and height sensors, not the adaptive dynamics system. Repairing the wiring obviously needed to be done, and good, but I don’t think that would throw the error you have. That throws an adaptive dynamics fault.
Thanks for the pointers - the car had been flashing up Adaptive Dynamics Fault at the same time as the suspension warning and the garage had previously diagnosed a faulty ride height sensor not giving a voltage output. There was a cross activation message on their Optimus (previously Autologic) system.
Indeed. You may have a mix of both, but in relative terms, if it’s a height sensor they are not daft expensive or too difficult to do. Consensus on here is to use genuine ones…. See what your garage says.
