Home > In Car Electronics (L322) > AUX IN
stu
AUX IN
can someone maybe confirm that there is the facility for "AUX-IN" on the face-lifted FFRR's?
i am trying to sort out an i-pod kit for the car and short of spending a few hundred quid on a Dension interface, i have seen some aux-in connectors with i-pod plug on the other end, which still allows you to charge the battery.
would the plugs be on the back of the tv screen in the dash? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71155 4th Jul 2011 6:35pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
I believe there is one in the glove compartment. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #71162 4th Jul 2011 6:50pm
trafpol
United Kingdom 2006 Range Rover Autobiography Td6 Buckingham Blue
Not in mine Sad 2006 MY Autobiography. With 'toys'
Honda ST1300 Pan European
Gone
Jaguar 3.0 SE X Type
Honda CBR1100XX Blackbird
TJF by the way for anyone who knows what that means.
Post #71191 4th Jul 2011 9:31pm
stu
is there any difference between the stereo system fitted in my face lifted FFRR 2006MY and the ones fitted in the 2007-9 MY's????? Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71362 6th Jul 2011 5:42am
Sea Aitch
England 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Mine hasn't got Aux In either. IIRC pre MY07 facelift models don't have it.
After a lot of head scratching I fitted the (quite expensive) LR interface device. Even though it is listed for MY07 onwards, there are threads on the forum showing how it can be done with a bit of fiddling about.It's compatible with the electronics, but you have to dismantle the dash, whereas the MY07 is more or less plug and play.
I now have a switch in the glove compartment to select between ipod and CD changer, and I use it to charge my iphone and use the ipod app in the phone through the touch screen in the car. Also, stating the obvious, the iphone operates on bluetooth to make and receive calls as usual. I had problems with this when I got the car, but I got it sorted with help from Wiggs (don't we all?).
Colin
Post #71372 6th Jul 2011 10:08am
stu
thanks for that, i thought things were prety similar. there only seems to be two choices if you want full functionality, L/R interface (Very Expensive) or Dension gateway 500 (Just expensive)... Shocked
we will get there in the end. wish it was as simple as the plug and play MDI kit i had in my Touareg. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71402 6th Jul 2011 3:02pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
Hi Stu
I'm working on another solution.
I found in the topix files for the 2006 Range Rovers a solution.
If you have rearseat entertainement there is this little panel with all the aux ports.
the video ports go to the entertainement module (which we dont have) but there is one AUX port in this thing which goes directly to the head unit.
this COULD be a solution. I have the wiring diagramms and technical explanation from LR but it is in german.
I have to open the dashboard to have a look if there is a connecter
Post #71407 6th Jul 2011 4:02pm
stu
Hi Hugi,
thanks for the reply, i think what you are looking into may be similar to this cable, which connects into the rear of the unit.
http://media-in-motion.co.uk/ipod-iphone-h...ca-output/ Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71438 6th Jul 2011 6:42pm
HUGI
Hi Stu
if I figure out how to wire in the so called Panel-AVI I may have an AUX-in.
check this out: (I know it is in german)
there we could plug in a cable like you mentioned before.
Post #71450 6th Jul 2011 7:43pm
stu
the cable that i posted the link for looks quite straight forward, just the aux plugs and a live and earth power supply.
this will help you get behind the unit, it is fitting instructions for a VIM unit, but gets you behind the head unit.
http://www.nav.tv/files/navtv-technical/VIMCANROV-RR..pdf Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #71454 6th Jul 2011 7:54pm
