Home > Technical (L405) > Can you identify this pipe?
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
I'm trying to tidy up my RR, which has had various clips lost or broken over the years.
Underneath the radiator is a small diameter pipe, just above the towing eye. I can't work out what system it is part of. I have checked the parts diagram for engine cooling, air conditioning, gearbox cooling, fuel cooling, but I can't identify it.
Can you name that pipe, please?!
Post #714041 14th Mar 2025 3:55pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Vacuum line to the csov at a guess as its located in the area. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #714048 14th Mar 2025 5:08pm
hmallett
Thank you! It seems that you are correct, the pipe is listed as "Compressed Air Recirculation And Shut Off Valve,Vacuum Control", and the plastic clip doesn't appear to be listed with a part number on the parts diagram, so I'll have to find an alternative.
Post #714050 14th Mar 2025 5:25pm
4RRS
It seems they come with the pipe, at a bargain £138!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #714065 14th Mar 2025 7:50pm
hmallett
I came to the same conclusion. My response?
Cable tie. 10p.
Post #714080 15th Mar 2025 12:17am
