![]() | Home > Technical (L322) > Ignition lock |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8549 ![]() ![]() ![]() |
Pretty sure that is an immobiliser fault, IIRC it was fuse 18 that covers this, a lot put a switch inline with the fuse so you just toggle it to get the key to turn, it eventually leads to component failure and you need a new lock...
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 596 ![]() ![]() ![]() |
Hi,
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 795 ![]() ![]() ![]() |
dont know about the 2007, mine is a 2005
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Steering lock mechanism on its way out, can fail in the unlock or lock position, you can get away with drilling a hole in the side of the housing in a particular place and lubricating but it's risky and doesn't last, really need an upper steering column to sort it out, expensive, or the bypass that's available about 60 quid iirc.
