![]() | Home > Technical (L322) > Parking assist system stopped working |
The plugs on the ECU? 2012 TDV8 Vogue (L322) |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
Correct. On mine the power/CANbus plug was fine, it was the sensor one that was affected. |
Pulled the plugs apart and all the connectors look clean and corrosion free so looks like the wiring to the sensors under the bumpers to check next although increasingly not too bothered by a non working parking assist. 2012 TDV8 Vogue (L322) |
camaro8199 Member Since: 18 Feb 2025 Location: South Carolina Posts: 2 ![]() ![]() ![]() |
Did you ever figure out the problem. My switch does nothing and I have already replaced the module with a used one. My module was bad and there was corrosion on the connector. I cleaned the connector metered the pins to make sure they were still good and replaced the module and still no joy. |
