Home > Technical (L405) > Upper tailgate fuse location
Nabbler
Wales
I have looked to no avail but the button on my upper tailgate isn’t lighting up but the lower is which has coincided in the tailgate opening on the fob and inside the car but will not close. No three beeps from the upper tailgate but beeps from the fob.
Any suggestions would be greatly appreciated 2025 SV P615
2021 SVautobiography Dynamic Black ( gone )
1997 C140 Mercedes Benz CL500
Post #712890 26th Feb 2025 9:23pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Check the switch, I had one on my L494 that had corroded and a pin broke off, guess it was when the tailgate had a leak. Just pop the switch out and check the 4 pins, if you have a multimeter you could check continuity also. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #712915 27th Feb 2025 8:52am
Nabbler
Wales
will do many thanks 2025 SV P615
Post #712918 27th Feb 2025 10:05am
