![]() | Home > Technical (L322) > Very noisy steering wheel 4.2 S/C |
tspd Member Since: 13 May 2024 Location: London Posts: 61 ![]() ![]() ![]() |
I’ve noticed a more frequent but intermittent sound coming from my steering wheel when being moved. At times the sound is completely absent!
Update on this. The noise was present prior to major work being recently done (rear subframe off, rear brake lines done, lanoguard, transmission fluids etc.) but since this work I've noticed the steering wheel is off centre as well. I'd say about 4-5 degrees tilted RIGHT to keep the car going dead straight on level road.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I took my wheel off and recentered no problem.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2276 ![]() ![]() ![]() |
Sometimes when they do the alignment they fix the steering wheel in place with the engine off and when they start the engine the wheel moves in out up down to where ever the memory tells it so it ends up off centre for the alignment - hope I have explained it ok |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1296 ![]() ![]() ![]() |
If I ever have to centre the steering wheel I adjust the track rod ends by doing one in one direction and the other in the opposite direction equal amounts.
I also replaced the steering wheel squib |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 205 ![]() ![]() |
How long since the power steering fluid was changed?
