Home > Maintenance & Mods (L322) > Rear LED light cluster (R/H) 2012 4.4TDV8 - Not Working
bwelton
United Kingdom 2012 Range Rover Vogue SE TDV8 Zermatt Silver
Noticed that my R/H Rear Light Cluster - Brake Light was not working.
These are the LED ones, so was wondering if it was the unit that has failed or something else. So I removed both sides and swapped them over to test. The R/H side is still now working even though the original RH is connected to the left side and working. So it must be the feed.
Any ideas is there are separate fuses or some control circuit that can be reset with IIDGap ?
Many thanks,
MY 2012 4.4 TDV8
Post #712710 24th Feb 2025 5:04pm
bwelton
All Sorted Now.
Read the faults with the IID Gap, there were a few open and closed circuit faults. I assume the Open CCT was as I had removed the Clusters to swap them over for testing. The Closed CCT may have been the case, but as ever a spurious Short CCT.
Anyway, cleared faults and everything is working again.
Let me know if I have missed anything. -------------------------------------
MY 2012 4.4 TDV8
Post #712711 24th Feb 2025 5:24pm
DrRob
Check the number plate lights. If one has blown it takes the light cluster power out too.
Check fuses too after new bulb in number plate light is fitted
Seen it a few times Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #712722 24th Feb 2025 8:46pm
