Home > Maintenance & Mods (L405) > MOT query - active anti roll bar pipes
Memoliito
United Kingdom 2016 Range Rover Autobiography 4.4 V8 Fuji White
Anyone know where to find set for Rear ace pipes and how many hours labour would it take
Post #712487 22nd Feb 2025 9:35am
fisha wrote:
Those hoses linked are for the older RR sport I think, and wouldn't be a straight fit on the fullfat. The ends joining the valve blocks are different.
That said, the principle of what they offer would work imho if applied to the L405. *
My caution is that their service relies on you sending the existing pipes which attach at each end to the valve block or the roll bar ... on mine, those sections were getting quite rusty ... so despite a new hose, I would expect them to continue to corrode and fail before the hose would ... greatly reducing the effectiveness / longer term value of the parts.
* There is debate about whether the hoses would flex / slap when being worked normally. The ACE system can send high pressure into the hose very quickly, which could make the hoses tense and pull against their mounts. This sudden tensing could possibly make them slap against surfaces causing sound, or rub and wear against fixed points - I've not read to date on this forum anyone who has a) fitted hoses b) experienced first hand the slap.
I was going down the route of sourcing hoses for myself before Mikey sold me a set of pipes. It still sits on my mind about creating hoses as a small project / exercise.
It says in the listing.... "We can supply kits for all Range rovers With ACE systems." So hopefully they do them for the 405... Thumbs Up Pete
Post #712490 22nd Feb 2025 11:09am
Memoliito
My mechanic spoke with them and they confirmed that they can do kit for L405 just need sending ends that bolt into the ARB and hydraulic distribution block and they will modify them
Post #712511 22nd Feb 2025 2:55pm
rstoughy
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
Mikey wrote:
If you have to use a dealer, that'll be about the figure
An indy will be around ½ that Thumbs Up
Apologies Mikey, I thought your comment was your price to do it Banging Head
Pity its such a long booking in time, tempted to trade it prior to that..
Post #712696 24th Feb 2025 12:50pm
