Home > Maintenance & Mods (L322) > Coolant Leak - What is this piece called????
Paul H
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Took my car in for a service today and drove about 10 miles before had the engine overheating warning come up.
Pulled over and couldn't find anything amiss, no mass of steam or gallons of oil under the car but got recovered to a garage.
They have sent me some pictures of the part that has broken but I cannot identify it in the parts catalogue at all and wondered if anyone could tell me please. Also they said the coolant wasnt circulating so that probably needs replacing too (not sure if the fact the system was no longer a sealed unit would cause that)
This is the part he is showing me (clearly broken) but the part it appears to be, circled doesnt seem to have a part number!
Help very much appreciated 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #712535 22nd Feb 2025 8:28pm
kevinp
I've just changed all my hoses and I think that one is LR022730.
Post #712538 22nd Feb 2025 8:49pm
Paul H
I think you are right - many thanks and looks a nice cheap fix too! Which always makes a nice change 2011 L322 Autobography - a lot of bells and some of the whistles...owner with no idea!
Post #712540 22nd Feb 2025 9:34pm
pcourtney
Is this a fairly common failure after 10 or 12 years of use, am wondering whether I should replace mine as they don't look brilliant to the naked eye, must get pretty hot around there near the bulkhead Sad
Post #712546 22nd Feb 2025 10:27pm
kevinp
Pete, I've just had to do my cooler and full thermostat housing. I've replaced all the hoses on top of the engine because everything was just brittle and snapped although there was nothing wrong with the actual hoses.
Post #712553 22nd Feb 2025 10:45pm
toby1
I've done the same as Kevin. My hose fell apart when I removed it (brittle plastic). I ordered a new set from Maltings. 2012 Vogue TDV8 in Aintree green over sand
Post #712570 23rd Feb 2025 9:43am
Ham
Bulgaria 2012 Range Rover Westminster 4.4 V8 Barolo Black
Was there any particular reason you replaced the thermostat housing or was it just precautionary?
Post #712702 24th Feb 2025 3:09pm
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
I have a leak at the same spot but I am not sure if replacing the LR022730 will be enough after looking the picture of LR022730. It doesnt seem to have the connector on it where I actually have a leak.
Can anyone tell me if I need to replace more parts?
Ebay picture of the LR022730 shows no angled connector?
Where I have a leak
OR does this part I marked above belongs to the hose connecting to LR022730? If yes what is the part number of this hose?
 2011 Vogue SE 4.4 TDV8
Post #713937 13th Mar 2025 8:27am
kevinp
Ham, mine was actually leaking from the temperature sensor.
Post #713958 13th Mar 2025 11:37am
Mfcetin
For or ring sizes, I found this:
https://www.fullfatrr.com/forum/topic58112...ring+sizes 2011 Vogue SE 4.4 TDV8
Post #714216 17th Mar 2025 9:34am
