![]() | Home > Technical (L322) > PDM Passenger Door Mirror Heater Output failure |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1234 ![]() ![]() ![]() |
A first step could be to pop the mirror glass out of the housing, and see what the condition is, that way you could check the condition of the wiring connection and heating element. It always seems to be the nearside mirror that suffers corrosion due to puddles / dirt etc against the kerb. Once popped out you could use a meter to check the connections.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
confirmed, I took both heated door mirror glass off, then ran IID Faults again
That is a good result, no messing around with wiring, and a cheap fix, decent quality replacements are about the £20 mark |
