![]() | Home > Technical (L405) > SDV8 strange HP fuel pump noise |
Astanavits Member Since: 23 Sep 2024 Location: Paris Posts: 15 ![]() ![]() |
Another exemple
Another one
Even a 2019 MY ??????? Listen at 0:59 ???? im not mad 😂
Update: Today I received and installed the stage 2 pump bosch 0986580131 / LR023043
Hi everyone, I received the new in tank fuel pump today and installed it, quick work, really easy unfortunately the sound is still present it has diminished but it is still present
Update: today i open the high presssure fuel pump to see if i found any scratch or wear on the roller or the plunger hopefully the pump is in perfect condition
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35644 ![]() ![]() |
the plot thickens....
Exactly, I think the problem is not mechanical but software. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
I’ve heard a lot of SDV8’s make this noise, mine does but yours does seem to have it bad, have you tried premium fuel, my own SDV8 does run better quieter on premium fuel. |
I've tried everything diesel cleaner, Total Excellium (premium diesel), nothing seems to work.
My current one is 2020, previous 2015 and both make this noise but more intermittent than yours sounds. It kind of comes in when full pressure is reached or that’s what’s it sounds like, then goes away, I work for a local indie where we work on lots of these and they all do it in varying degrees so I’ve put it down to a characteristic of the engine. But I do think premium fuel helps mine. Hope you get to the bottom of it. |
