Home > Maintenance & Mods (L322) > Gearbox oil level check; On lift or On Wheels?
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
Question in the title, how should you carry out the level check, on a two post lift or with the wheels on the ground....does it make any difference? If the car is supported on the lift at the chassis or jacking points is it level? All the best
Chris
Post #711567 11th Feb 2025 1:31pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
There's no difference either way. Critical is to have the car level - which might be more likely with the lift dependant on the surfaces you've got available. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #711589 11th Feb 2025 7:00pm
