![]() | Home > Maintenance & Mods (L405) > 2014 Original steering wheel buttons upgrade to 2018 ones |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
I've read somewhere that you can fit the later steering wheel buttons to the pre facelift with a new loom for them...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35479 ![]() ![]() |
Craig came to mind and i found this,
Thanks Stan and David...
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 ![]() ![]() |
I wouldn’t bother - I much preferred the earlier steering wheel buttons which are a more positive click. The new type are dreadful and feel cheap and nasty - plus you knew when you had activated the button - the new type are not consistent and seem to need varying amounts of pressure. Ditto the door mirror switches. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3862 ![]() ![]() ![]() |
Has anyone got any experience of just wiping the old sticky stuff of with Isopropyl rather than what seems a risky venture to Ali Express or an expensive venture to JLR? Geoff |
Vogue, I'm glad you said that, that's the problem with the aftermarket ones I bought, they don't work each press of the button, just sometimes.... anyway I'm going back to the old ones and I'll forget about the new ones. Cheers |
This ^ sounds exactly like my genuine factory buttons - I positively hate them - the original pre-facelift switches were far better !
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1578 ![]() ![]() ![]() |
#3.
Thanks guys, going to stay with the originals, lucky it's only a 10min job to change them.... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1408 ![]() ![]() |
no message. oops. V8 or else ... |
sgorianin@gmail.com Member Since: 11 May 2021 Location: London Posts: 26 ![]() ![]() ![]() |
I would say buttons look fine a bit modern but still far from perfect.tactile feelings of them completely different and response often lost so you barely know if it pushed or not.
