![]() | Home > Maintenance & Mods (L322) > 4.4 tdv8 EGR and Dpf |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 841 ![]() ![]() ![]() |
My 2011 4.4 TDV8 had a EGR delete in software ( and Economy Remap at the same time ) about five years ago, and it really helped with engine power and a much cleaner system all round.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2555 ![]() ![]() ![]() |
AU versions (ROW?) weren't fitted with a DPF and I know that the DPF can be deleted from the software if the remappers are prepared to do it.
maz Member Since: 28 Sep 2024 Location: Perthshire Posts: 6 ![]() ![]() ![]() |
?si=pt2yhH1qTidZ80Li 2011 4.4 TDV8 Vogue Grey/Ivory |
Wish Member Since: 17 Jan 2025 Location: Riemst Posts: 22 ![]() ![]() ![]() |
Thanks,
you don't need to remove the EGR ( or blank it or delete it ) , you just need it to be done using software, if you are in Belgium coming to UK to get this done, then the man that did mine is near Harlow in Essex
Hello,
Will your OBD scanners work with the "Car Scanner App" used in the below thread ??
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1261 ![]() ![]() ![]() |
Hi Pete.
Kevin, yes it was the only reason ( 5 years back )for me to get the EGR delete done in software and the remap done, and it worked, she flies off from standstill, and still does to this day |
I will have to try and find someone local to get it done. It's my only gripe with how it drives.
Mine is a Viezu fuel efficiency remap. Perhaps give Viezu a call or find a dealer local to you from their website. |
Thanks 👍 |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 155 ![]() ![]() ![]() |
I have been trying to keep an eye on my DPF load using a GAP IID BT tool, but it doesn't show up in the list of modules anywhere that I can find it.
Live Values on the GAP IID
