L322 2004 Td6 RR Vogue - Engine Dies without warning | |
Hi All,
Occasionally, my Vogue just dies as if I have switched off the ignition. This happens when stopping at, say, traffic lights. If if put on the handbrake, put her into park then switch off the ignition and on again and she starts fine and drives OK.
I usually leave the status bar showing the range left. After this happens, the status bar resets to a blank display. 4 presses of the stalk button and the range displays again.
Which ECU maybe a fault here? It is as if the ECU has simply reset.
My IIDTool reported an error message (can't remember it) which cleared when I restarted her.
Anyone else had this problem?
Cheers
Gary
