Home > Technical (L322) > 3.6TDV8 cranking and not starting
Rackers
Leak off pipe had to be replaced but the filter and lines were disconnected during the replacement.
I've tried bleeding the low pressure side but I just can't get this thing to fire up.
Is there a specific procedure to be followed to bleed it properly?
Tried so far.
Ignition on 30-40 seconds, repeat four times.
Connected up an old tyre pump hose to the schrader, ignition on 30-40 seconds but the flow seems to stop after 15-20 seconds, I thought the low pressure pump would run longer than this?
I do have a P0191-23 code stored.
Prior to the work being done car started with no issues.
Thanks all
Post #710748 1st Feb 2025 11:08am
GraemeS
Australia
From the WSM...
Fuel Rail Pressure Sensor A
Circuit Range/Performance
Fuel rail pressure (FRP)
sensor circuit
range/performance - signal
stuck low
Low fuel level
Blocked/incorrectly
connected low-pressure fuel
lines
FRP sensor circuit short
circuit to ground
circuit to power
FRP sensor circuit high
resistance
FRP sensor fault
Fuel pump module circuit
short circuit to ground
short circuit to power
high resistance
Fuel pump module fault
Check the fuel level and the condition and correct
connection of the low-pressure fuel circuit lines
(incorrect connection of the lines to and from the fuel
filter can cause serious fuel pressure fluctuations).
Check the FRP sensor and circuits. Check the fuel
pump module and circuits. Refer to the electrical
guides. Repair/renew as necessary. Clear the DTCs
and test for normal operation.
Post #710788 1st Feb 2025 7:41pm
Rackers
Thanks GraemeS
I've got a replacement battery booster arriving tomorrow so going to get SDD loaded up and do some logging. I'm going to try running the fuel priming routine to see if it helps.
I have a fuel guage issue (typical sender issue) so the car thinks the tank is empty. Referring to the WSM, is it talking about physical low-level or perceived low-level?
Cheers
Post #710792 1st Feb 2025 8:33pm
GraemeS
Australia
I assume actually low because if only perceived low shouldn't cause a fault code.
Post #710803 1st Feb 2025 11:41pm
