Home > Technical (L405) > 4.4 instant restricted performance
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Evening all. New to me 2014 tdv8 and I get restricted performance and can even get it to do it stood still with light revs. Codes are similar to what leads people to check vacuum control pipes which I’ve done and checked the csov with vacuum which is moving. The only thing I’ve noticed so far is the maf live data on bank 1 goes higher than bank 2 and that seems to be when the fault triggers. This would make me think air leak somewhere but nothing showing with quick smoke test(will try again tomorrow) can’t recall codes as solus has just gone flat and haven’t got the charger with me! Any ideas and help much appreciated. Thanks. J
Post #710624 30th Jan 2025 9:32pm
fisha
Almost impossible to say without codes at this point. V8 or else ...
Post #710636 30th Jan 2025 10:34pm
GraemeS
Australia
MAFs are for the primary and secondary turbos, not bank 1 and 2. Airflow through the secondary turbo will be virtually nil unless the secondary turbo is working.
Post #710637 30th Jan 2025 10:36pm
Jimes256
Last code was p00bf air flow too high. Previous was that and p004d p004b boost control solenoid b circuit high and circuit range performance
Post #710673 31st Jan 2025 9:32am
GraemeS
Australia
Does it have fitted the additional short loom between the side of the sump and the primary turbo that's meant to stop oil migration along the oil level and temperature sensor harness?
Post #710680 31st Jan 2025 12:27pm
Jimes256
Not sure I’d have to check
Post #710689 31st Jan 2025 1:57pm
Jimes256
One thing I did notice was the csov was slow in movement when I put vacuum on and released
Post #710690 31st Jan 2025 2:19pm
kevinp
I know when I tested mine with a vaccum it closed with a good 'thunk'.
Post #710704 31st Jan 2025 5:43pm
Jimes256
Yeah thought it should. I’ll have to see how quick the gun releases vacuum and just pull pipe to check
Post #710714 31st Jan 2025 6:33pm
Jimes256
Returning fault is p00bf mass air flow b circuit air flow too high
Post #710778 1st Feb 2025 6:47pm
Jimes256
P004d-77 and p004b-71 are the codes I can’t get on top off. Anyone had the same?
Post #710838 2nd Feb 2025 3:06pm
Jimes256
For anyone that may encounter the same, turned out the vent to airbox and vacuum supply lines were the wrong way around. Took a while to notice but got there in the end!
Post #710839 2nd Feb 2025 4:38pm
kevin-t
Just a thought!
Skip to 37 mins....
Post #710842 2nd Feb 2025 4:53pm
GraemeS
Australia
Excellent! If only all faults were that easy to fix.
Post #710873 2nd Feb 2025 8:47pm
Jimes256
kevin-t wrote:
Just a thought!
Skip to 37 mins....
One of my first checks!
Post #710880 2nd Feb 2025 10:43pm
