![]() | Home > Maintenance & Mods (L322) > Rhino Rack roof rack mounts? |
MilesBFree Member Since: 07 Nov 2023 Location: SC Posts: 23 ![]() ![]() |
hi, I found a set of Rhino Rack mounts that are supposed to fit the L322 and which will take most roof racks, but when i went to install them the legs on the bottom of them seem too tall and the base of the mount is about 1/4" or 6mm in the air above the roof.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1542 ![]() ![]() |
I have a Rhino Pioneer Platform on my L322.
Thanks for the reply, Ron.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
I have used the same Rhino Rack mounts on an 2007 and a 2012. There is no difference between the models as far as the roof is concerned.
I was kinda tempted to buy 8mm bolts and do away with the brass mounting studs entirely but
I was working with etrailer.com, where i ordered the mount kit from. But they were not able to answer the question on the gap and could not order the brass stud mounts, so they referred me directly to Rhino Rack. (I will put in a good word for etrailer - they were very responsive and tried to help)
So I'm looking at the Front Runner rack and it appears from what i am seeing that there might be 2 long rails that bolt to the roof, and then their mounts bolt to those? Its sort of hard to tell given the mounts are in the shadow under the main rack.
Forgot to add: he said the reason for the gap is that the version of the cars that went to Australia (where the main company is located) seem to have a slightly different trim on the roof mounting system than the US ones do.
OK, I was thinking about buying a sheet of 80A hardness EPDM and cutting pads for under the mounts since several of the photos others have posted do show a small gap too. And I never liked the idea of the mounts scratching the roof of my car.
The outer skirt is purely cosmetic and does not make any load bearing contact with the body. The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
Rhino Rack tech support said it is, and the load is supposed to be spread across the entire base.
