Home > Maintenance & Mods (L322) > Installing a 020 battery into a 2007 TDV8 rhd
rscsmith
All,
I’ve just changed my battery to a Varta I1, size 020 (£145 delivered from Tayna). This is one size bigger than the OEM battery, which is size 019. I’d read lots on the forum about using a 020 and decided to take the plunge. It just about fits, but I thought I would record how it went here in case it’s of use to people. It's not without its trials.
Car: 2007 Vogue SE 3.6 TDV8, right hand drive.
1) You need the bonnet in the service position. The job would be nearly impossible if it’s down.
2) I had a mate to help me. It was a struggle with two of us. He was stood next to the car on a step, I was kneeling on top of the engine. It might be ok if you have biceps like tree trunks, but this is a 25kg battery that needs to be threaded into a very tight space – it’s not a simple exercise to drop it in. There are cables and the washer hose in the way, so a spare hand or two is needed to avoid snagging these.
3) I put a 12V supply onto the car from my CTek MXS10 charger (which has a supply function for this purpose) so I didn’t have to reset windows, steering sensor, etc. Of course, this meant the positive terminal stayed live, even after the battery is removed, so I wrapped it in a rubber glove to avoid accidents. I ran a cable tie down from the wiper to hold it out of the way. I cable tied the negative to the bonnet support.
4) The battery is slightly too long. There is a flange along the bottom of the battery (used for tying the battery down). The flange was clashing with the inner wing. This meant I couldn’t get the +ve terminal on as the battery was too close to the centre of the car and the heater box (I think). I had read about this somewhere. Since this flange isn’t used for tying down on the RR, I used a Dremel with a cutting disk to cut it off, making the side of the battery flat at the bottom (negative terminal side). This meant the battery could now be hard against the inner wing. I also removed some insulating material.
It is worth considering that this has probably invalidated my warranty. I may well just stick with a 019 next time, as that is what the car is designed for.
5) The positive terminal has a fuse box beneath it. This fuse box wraps around the top flange of the battery, i.e. the box is thinner at the top than at the bottom. It wouldn’t squeeze past (what I think is) the heater box once the battery was in position, so I had to install the terminal with the battery halfway out, then drop the battery the last few inches. Another reason for that second pair of hands, to hold it up while the terminal is moved into place. Also of note - if that fuse goes, I'll have to lift the battery to access it.
In short, a pain in the neck to do, but it’s in and the car now starts with enthusiasm. Looking forward to using my FBH on the next cold morning.
I would be interested to hear if I've missed anything that meant all this was not necessary. Perhaps it's only Varta batteries that are tight and other brands fit better.
Cheers, Rob '07 Range Rover Vogue SE TDV8
Post #659761 18th Mar 2023 5:54pm
tspd
Thanks - going to do this myself. Presumably the battery clamps that you unscrew don’t fit? Any thoughts on this RE safety etc? L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
133k miles and counting
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'19 First Edition Velar
'22 XC90 II
'24 L322
Post #710268 26th Jan 2025 7:49pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
Hi,
On mine I cut the original clamps down and rebent them, but you may need to file the foot by the threaded hole, I did mine with a dremmel grinding stone just to expose access tothe mounting thread.
With the bigger battery and the ECU and other brackets crammed in there, that battery isn't going anywhere.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #710273 26th Jan 2025 7:57pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
Excellent thread, thank you! Mine will probably need a battery next autumn in prep for winter and I’ll probably go this route.
One for the WIKI @Stan ? TDV8 4.4 2012
Post #710287 26th Jan 2025 10:35pm
tspd
+1 did this today. 020 Varta fitted into ‘07 supercharged.
Only mod was the side plastic dremel removal. Clamps etc fitted as normal and fuse wasn’t too tightly pushed up on positive side.
THANK YOU! L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'22 XC90 II
'24 L322
Post #710773 1st Feb 2025 4:57pm
