Home > Technical (L405) > L405 FBH remote pairing
Andy66
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
hi people ive got a 2013 l405 sdv8 lovely car, the fuel burning heater works great, want to upgrade with remote, ive bought remote which is one with fan and heat rising for on, cant get it to pair, can anyone talk me through procedure from start to finish, thanks in advance.
Post #710019 23rd Jan 2025 10:39pm
E500
I think you may have the wrong fob for your car.
If I'm correct, the later cars have Webasto heaters which use the fobs with the little heat design. The earlier cars likely have the Eberspacher heater which uses a different fob. You can check yours by looking at the heater under the bonnet (Google will help you with finding the location, it's fairly easy to see). Or you can look at the module in the D pillar, I think they say Eberspacher and/or Easystart on them if you have the Eberspacher heater.
Anyway, the process is:
(Optional step 0): Remove the battery from the fob for a while. Unknown if this helps if the fob is already paired to a car.
1. Pull the fuse (exact fuse depends on the car but it should be described in your manual) and wait 5-10s.
2. Put the fuse back in, then press and hold the 'OFF' button on the fob. You should see the LED light uo red for a couple of seconds.
This post contains some more info: https://www.fullfatrr.com/forum/topic57037-15.html
Post #710039 24th Jan 2025 11:19am
baz000000
England 2016 Range Rover Autobiography SDV8 Loire Blue
This video will fill you in on all things FBH.
Post #710621 30th Jan 2025 9:18pm
Andy66
watched that one baz
Post #710627 30th Jan 2025 9:45pm
Andy66
E500, i think pour right, it is eberspatcher so remote fob is the one with on and of i think?
Post #710628 30th Jan 2025 9:48pm
