Home > Technical (L405) > L405 FBH remote pairing
Andy66
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
help would be appreciated, ive got 2013 L405 sdv8, when pairing your FBH remote should ignition be on or off when fuse removed,
Post #709833 21st Jan 2025 8:41pm
E500
Off. At least that's how I did mine.
Pull fuse for 30s or so, put it back in and press the 'off' button on the fob immediately.
Post #709914 22nd Jan 2025 6:39pm
Andy66
thanks E500 i will leave the fuse out longer, and try again, any idea of exact location of reciever on L405 as can not find it?
Post #709923 22nd Jan 2025 9:05pm
mpirie
Which fuse do you need to pull for 30s?
Mike
Post #709942 23rd Jan 2025 8:35am
E500
This thread helped me. https://www.fullfatrr.com/forum/topic46437.html
On my car (MY16) the fuse was in the passenger footwell fuse box. I think it's fuse 1, but you should be able to check in your manual.
The receiver itself is in the OSR wing I believe.
This thread, about retrofitting the whole system, contains some good info about where the receiver is: https://www.fullfatrr.com/forum/topic57037.html
Post #709948 23rd Jan 2025 9:23am
Andy66
As soon as I get chance i will pull fuse wait longer than I did last time which was about 10ish seconds and see what hhappens, appreciate the input thanks
Post #709957 23rd Jan 2025 11:22am
