Home > Technical (L322) > Fuel gauge only goes to a quater tank.
shedjim
United Kingdom 2004 Range Rover Vogue SE 4.4 V8 Java Black
2004 l322 $.4 V8 Petrol
I filled up with petrol yesterday until the pump clicked off. when I started up again the gauge was at the same level 1/4 tank showing.
The gauge is still going down, now showing 1/8 of fuel left and 60 miles range.
I've tested with my gap iid and its showing 0xD7 fuel sender 2 fault.
Having searched the wonder web I have a couple of questions.
1 Will it cut out when the range reaches 0 miles ?
2 With an almost full tank of fuel will I still be able to remove the senders without flooding my car with petrol ? (I think this wil be fine looking at the shape of the tank.)
I'm guessing its either the second sender thats faulty or the connection in the tank is faulty.
Any help/advice would be great.
Thanks Jim
Post #567988 25th Sep 2020 1:59pm
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Hi did you solve the problem?I have very similar problem only showing 50% full.Will it cut out with a half tank of diesel but indicating empty??
Thanks 2012 TDV8 Vogue SE 4.4
Post #709879 22nd Jan 2025 10:39am
D3Jon
There's a known issue with the sender wiring under the rear seats of the L322.
A quick search should find you the info you need.
I'll have a quick look for you now, whilst I have a cuppa.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #709880 22nd Jan 2025 10:47am
D3Jon
Have a read through these:
https://www.fullfatrr.com/forum/topic41061...uel+sender
https://www.fullfatrr.com/forum/topic46574...uel+sender
Without going through the threads in detail myself, the issue here seems to be a wiring connector within the tank, between the top cover and the pump / sender.
Not a job I've ever had to do.
I'm sure there is also an issue with the (external) wiring under the seat itself, so maybe worth wiggling them around and cleaning the contacts whilst observing the fuel gauge to see before diving into the tank itself.
Good luck,
2014 Disco 4 HSE
Post #709882 22nd Jan 2025 10:59am
kevinp
I would ignore the last five words of Jon's advice.
Sorry, couldn't help myself.
Rolling with laughter
Post #709893 22nd Jan 2025 12:29pm
D3Jon
Err.. yes, don't 'actually' do that Rolling with laughter Rolling with laughter 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #709895 22nd Jan 2025 12:34pm
p38arover
Australia
What? "whilst I have a cuppa."? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #709938 23rd Jan 2025 2:05am
D3Jon
Just as dangerous as "diving into the tank itself" Ron Laughing 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #710036 24th Jan 2025 10:19am
