Home > Technical (L322) > Vacuum lines 4.4 tdv8 l322
Wish
Belgium 2011 Range Rover Vogue 4.4 V8 Java Black
This.
Post #709561 18th Jan 2025 4:00pm
Wish
I just cant see enough,
Multiple lines are loose.
Thinking about removing the complete front end to see whats going on ๐Ÿ˜….
Need to change the coolant anyway cause i change the oil cooler gaskets en o rings.
Anyone has a diy to strip the front end with radiators and all?
Post #709639 19th Jan 2025 12:03pm
mgrover
i mean defo would make it easier. if you do that though id say so the pulleys too and whatever else whilst your there.
also yes i did mean those screws Its actually a sport Sad
Not anymore, 4.4 TDV8 now Very Happy
Post #709641 19th Jan 2025 12:13pm
Wish
Yes,
Already started removing some parts.
I cant find a diy on youtube or i net how to do it step by step.
Just doing random right now ๐Ÿค
Post #709642 19th Jan 2025 12:15pm
Wish
Finally all vacuum lines are fixed.
Im building everything up again but i have a problem with the wiring that runs right from the fan cover.
Does anybody have any pictures of where they are held? There are clips but i cant seem to fund the holes anymore ๐Ÿ˜….
Around the waste gate actuator and moving upwards from there.
Post #709993 23rd Jan 2025 5:51pm
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi wish
Any chance you have a diagram of how lines are meant to be fitted please? Albeit for a 2014 I canโ€™t find anything anywhere of any detail!
Thanks
Post #710387 27th Jan 2025 9:51pm
Wish
Hello,
I used this.
Gr
Post #710389 27th Jan 2025 10:13pm
Wish
O0
Post #710390 27th Jan 2025 10:15pm
Jimes256
Thanks. Itโ€™s mainly the 2 that go across the top at front. Think they may have been swapped over where they go into larger joiners to left of vacuum pump
Post #710413 28th Jan 2025 10:01am
