Home > For Sale & Wanted > [Wanted] Rear brake pad wear sensor wiring plug
RG2024
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Anyone happen to have the plug which goes on the end of the wiring loom for the rear brake pad wear sensor, ideally with decent tails on it?
Went to plug my new one in today after fitting new pads & discs, opened the plastic box in the arch & to my horror found 2 standard male spade connectors fitted to the end of the loom. Wrong sex & far too big for the plug I was hoping to connect up to it. I'm sure I could find a way, but it would be so much easier if I could just solder the correct plug on. '95 VW Corrado VR6
'97 VW Golf VR6
'16 VW Golf R Estate
'23 Porsche Taycan GTS
Just bought '06 Range Rover 4.2 Supercharged
Post #709588 18th Jan 2025 8:18pm
dhallworth
Is it the plug from the wear sensor you need or the plug that goes onto the wiring loom on the car? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #709601 18th Jan 2025 10:08pm
RG2024
It’s the one that goes on the wiring loom '95 VW Corrado VR6
'97 VW Golf VR6
Post #709621 19th Jan 2025 8:31am
dhallworth
Ahh, I have an old wear sensor here that I'm about to chuck out so was going to offer that if it was what you needed.
Might be best to reach out to one of the sellers breaking one on eBay. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #709634 19th Jan 2025 12:21pm
RG2024
Have tried that, waiting on a response. In the meantime I think I’ll try some power timer connectors instead. Just don’t know which wire goes to which pin, possibly doesnt matter as long as there’s a circuit
Can’t find a wiring diagram for them though '95 VW Corrado VR6
'97 VW Golf VR6
Post #709637 19th Jan 2025 12:51pm
