![]() | Home > Technical (L405) > Possible Turbo issues |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1749 ![]() ![]() ![]() |
OK - So where does all this really leave me.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1272 ![]() ![]() ![]() |
Just a stab in the dark, check the filter drain bung that sits directly under the oil filter is sitting on it's locating post. Just take the filter off and have a look.
Thanks Kevin.
It's worth pointing out both suggestions mate.
Thanks Kevin
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2568 ![]() ![]() ![]() |
Oil pooling in the turbo isn't the fault of the turbo. If the turbo isn't being used then oil will pool and from what you've posted, replacing the turbine valve would be my 1st step after checking that the drain valve in the oil filter housing is still in-situ. |
Thanks Graeme,
When my oil filter valve was misplaced it used 3 litres of oil in less than 600 miles.
Thanks Kevin,
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
Morning Comports,
Hi Ash, I have an L322 but I presume the COSV is in the same place as yours.
To be clear, the CSOV shuts-off the intake air to the secondary turbo whereas the turbine valve shuts-off the exhaust at the secondary turbo.
Thanks Graeme, it is CSOV, crossover shut off valve. Always spell it wrong!! |
Thank you all.
