![]() | Home > Wheels & Tyres > Going from 255/50/20 to 255/55/20 - L322 |
The speedo will read either spot on or slightly under read your actual road speed so you have to be more careful with watching your speed. This can be adjusted with the GAP-IID tool though. If you are drag racing and throwing it round bends at the limit of traction the tall sidewall may slow you down a bit but most people preffer the look and slighly better ride quality. 2012 TDV8 Vogue (L322) |
markh1 Member Since: 12 Dec 2024 Location: surrey Posts: 21 ![]() ![]() |
Thanks for that, certainly not going to to be doing drag racing or cornering hard.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1258 ![]() ![]() ![]() |
I bought a set of wheels that came with 55 ratio tyres fitted and was surprised at how 'mushy' the ride felt with just the 5% difference.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 835 ![]() ![]() ![]() |
same for me, had 55's when I got the car (they had about 5mm on them at the time) , nothing too bad about them
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
Not to do with performance but I reverted to 255.50.20 because, with advancing years and some health problems, I found it very difficult to get the 255/55/20 out of the boot, even with the spare wheel lift.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
Tyres will each have their own characteristics so that will be a factor, but my experience was much as that of others here, ie 50 profile gives quicker and sharper steering responses, 55 a more cushioned ride.
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 115 ![]() ![]() |
I did what you're looking at doing, going from a mixed bag of 255/50/20s to 255/55/20s. Obviously, switching from cheap rubber front and rear to quality rubber all round made a huge difference to both comfort, noise and driving feel. Regardinghte speedo, it now reads spot on with GPS via Waze. Not ideal as I'd rather it reads slightly over so I'll use the Gap IID tool to change things.
Thanks for all the replies.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 ![]() ![]() ![]() |
I have two sets - summer and winter the winters on 19 rims the summers on 20 I run 255 55 tried the pirellis but too soft for me I have Pilot sport for the summers side wall a lot stiffer than others so not too much of a compromise on feel and for the winters Goodyear ultra grip on 19 which are a lot softer so a lot of the difference can be just the tyres.
