Home > Technical (L322) > Charge System Fault (solved)
ebajema
Hi all, just wanted to share something.
I had a Charge System Fault for the past few days and due to lack of time and pouring rain, I didn't get around to a good look till tonight.
I was worried it was the voltage regulator or entire alternator.
What I did notice is that my cheap cig lighter voltage meter showed 13.6 to 13.7 volts, rather than the 14+ volts normally, so it was charging.
Since it had work done recently and I drove it across a gravel road this weekend (the Forgotten World Highway in Taranaki NZ), I was wondering that it was it was a connector/cable issue.
It turned out to be really simple, there is a little plug on the negative pole clamp that had come loose. So I plugged it in and that was it.
So next time you have a similar issue, check that little plug first !!!! MY 2010 5.0 SC Galway green and sand interior!!
Post #569682 13th Oct 2020 10:29am
Apps
United Kingdom 2010 Range Rover SE TDV8 Santorini Black
Hi. I'm having the same issue. Any chance you can upload a picture of the plug you was on about
Post #709250 15th Jan 2025 8:32pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
I had exactly the same issue, and was told I needed a new alternator despite it being only 4 years old. I fiddled with the battery condition monitor connector at the battery, and 3 months on the fault has not returned. Nothing like a free fix! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #709304 16th Jan 2025 12:24pm
Apps
It appeared last year so had new alternator and battery fitted but still comes up then goes off.
Post #709316 16th Jan 2025 1:15pm
