![]() | Home > Technical (L322) > Fuel sender issue |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 528 ![]() ![]() ![]() |
It's a common issue, you'll find it well documented on here if you do a search. You can get by with a temporary variable resistor to mimic the output of the tank sender. The actual fix requires you to get inside the tank to repair the wiring. 2016 Skoda Octavia VRS Estate
eg https://www.fullfatrr.com/forum/topic41061.html 2016 Skoda Octavia VRS Estate
Jimmy86 Member Since: 27 Feb 2024 Location: East midlands Posts: 21 ![]() ![]() |
Brill. Thank you MikeO. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 757 ![]() ![]() |
On my 4.4 the engine would cut out without warning when it decided to protect the fuel pump from running dry.
Thanks. Will do. It's off the road for the next week or so to get some jobs done and this one is on the list. |
Afternoon All.
I used a basic crimping tool. You should have no issues. Make sure the wires are nice and clean. Use the right size crimp connector (should be a snug fit). Don't be tempted to 'double crimp'. Try to get it right first time. Nice and positive. Then a gentle tug on the wires afterwards to confirm they're crimped well.
They're are lots of YouTube videos too. Worth a watch. 2016 Skoda Octavia VRS Estate
Brill, thank you. Probably ovwr thinking things in terms of the tool. Yep, under a quarter of a tank left, so now seems to be a good time. I've ordered the official repair connectors so hopefully they'll be the right size. |
Ah, my only concern would be whether or not you need a special tool for those special crimp connectors. Sorry, I didn't realise you meant could you use a normal crimping tool with those. I used normal crimp connectors and it worked just fine. 2016 Skoda Octavia VRS Estate
I do have some normal connectors too so could always use those. Will see what the official connectors look like when they arrive and make and decide.
