Home > General (L460 2022) > Mild Hybrid ??
Baltic Blue
Mild Hybrid ??
I must be getting old, my son has just upgraded his discovery 5 to a new D350 Defender after 6 years of trouble free ownership.
He tells me that it is a “mild hybrid “, but I have never heard of the term and keen to learn .
Please can anyone educate me better than Google which suggests the term differs from manufacturer to manufacturer. .
Thanks
Post #709218 15th Jan 2025 5:33pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
It wont help with reliability........
Its just something else to go wrong and need replacing under warranty
Post #709224 15th Jan 2025 6:10pm
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
MHEV vehicles just employ a small electric motor and battery, which is charged via re-gen from engine braking. They cannot run on electric power alone, but use the electric motor to increase overall “power” of the vehicle and general lower emissions.
As opposed to PHEV….larger motor, battery and plugged in charging, solo EV running if required.
….and then pure EV…previously only offered by Jaguar in the JLR portfolio, but forthcoming Landrovers soon. L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #709226 15th Jan 2025 6:13pm
dingg1
No idea tbh
But hired a ford kuga hybrid a few weeks ago, did 340 miles in it and it cost me 45 quid to refill the tank, quite impressed with the performance as well.
Next car will most likely be a hybrid of some sort, but the sc is still going strong and turned into a bit of a triggers broom.
Post #709229 15th Jan 2025 6:26pm
00by
AFAIK the JLR MHEV system is an electronic supercharger that increases the pressure in the turbos at low RPM.
So less lag, improved response/drivability, more power lower down the rev range and better economy.
Post #709303 16th Jan 2025 12:12pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
As above, it’s a 48V motor that provides mild assist and does the stop/start stuff, fed from a little battery that charges under deceleration.
Post #709313 16th Jan 2025 1:04pm
Baltic Blue
Thanks to everyone for sharing their knowledge.
Cheers
Post #709351 16th Jan 2025 4:38pm
Cav
If I stick at a real 70 on the motorway it will return an indicated 40-41mpg. 2021 Westminster Black D300 MHEV
1990 3.9 V8 manual Vogue - sold in 2000
Post #709370 16th Jan 2025 7:06pm
