Home > Technical (L322) > 3.6 Vs 4.4 L322 |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 |
Sounds like a plan to me!👍 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice! Alfa Romeo Giulietta Just one Montesa now, 349 White Wonder Austin A40 Farina MK2 1975 Morris Marina 1.8TC 1973 Honda CB250 K4 |
14th Jan 2025 1:05pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I'd suggest at least £5k for repairs esp if you have to pay a garage to do the work. 2012 TDV8 Vogue (L322) |
14th Jan 2025 1:36pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 387 |
I’d agree with JayGee in as far as £100 per month is nowhere near enough for “maintenance” depending on what you call maintenance!!
14th Jan 2025 1:50pm |
Stefanbutler Member Since: 03 Dec 2024 Location: Belfast Posts: 6 |
I really appreciate all the advice I got on this. Thank you |
15th Jan 2025 9:31am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 450 |
If you're keen on a warranty, you may need to go down the 4.4 route anyway.
15th Jan 2025 9:43am |
Even the newest 4.4's are 13 yrs old now so a warranty is likley not going to be worth anything. 2012 TDV8 Vogue (L322) |
15th Jan 2025 11:10am |
ianmacd Member Since: 20 Aug 2013 Location: Sussex Posts: 202 |
Depends what your driving profile is like. I have had both and went back to the 3.6 as my current profile for this vehicle is small short trips so lack of a DPF is a bonus. I had forgotten how much more the 3.6 with the 6sp revs compared to the 4.4 with the 8sp though when I went back into a 3.6. Current: RR L322 2010
15th Jan 2025 11:33am |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 182 |
I looked long and hard at various FF's both 4.4 and 3.6, diesel and petrol variants, for me the problem with the 4.4 diesel is the DPF, not being able to cruise at reasonable speed for 20 or so minutes to clear the DPF was a deal breaker. the petrol version did look fab, until you hang a large trailer behind it and the range drops alarmingly. Therefore a 3.6 facelift was bought, EGR blanked and written out with the GAP IID, heavy duty towbar fitted, all fluids, alternator, pulleys etc., brake disks and pads, front suspension bushes changed. I have done this over the last 4 years and to me it is still a joy to drive and I hope it will serve me for a good while yet or for as long as our overlords will allow the sale of hydrocarbon fuels.
15th Jan 2025 9:54pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2516 |
I agree that if doing a lot of towing then the 3.6 with the 6-speed gbox is a good option. My brother has a 3.6 RRS used solely for towing his caravan and off-road camper trailer, not that a 4.4 was an option for him. I work at keeping my 4.4 in a lower gear when towing my caravan because IMO the 4.4 too readily works hard at lower revs yet the 4.4 has exactly the same main and big-end bearings as the 3.6. If not towing then my 4.4 which doesn't have a DPF has much better fuel economy. |
15th Jan 2025 11:31pm |
Bilbo Member Since: 22 Sep 2024 Location: Midlands Posts: 2 |
Thanks ianmacd, very useful informationhttp s://www.fullfatrr.com/forum/images/smiles/icon_thumbs.gif Are you able to offer any other driving differences, .....good or bad, depending on how we all drive in different ways? |
16th Jan 2025 8:19am |
There is a ‘theory’ that the gearing on 4.4 which aids economy could compromise lubrication under high load / low rpm due to reduced oil flow. This may have been fixed in software updates and I find under potential low speed / high load situations such as hills that the gearbox will hold lower gears and let the engine rev higher than feels necessary. Given the scarcity of 4.4 engine failures this doesn’t sound like a problem. 2012 TDV8 Vogue (L322) |
16th Jan 2025 9:00am |
JamieShand13 Member Since: 07 Nov 2023 Location: East Yorkshire Posts: 15 |
Another 3.6 fan...I was beginning to think they didn't exist! Similar first year to mine, albeit with some undersealing thrown in for good measure. Albeit she's on 140K now so I'm hoping I get a couple of years of spend free motoring (outside of regular maintenance). Wishful thinking perhaps.... |
16th Jan 2025 12:26pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3240 |
I have had my 3.6 for coming up to eight years. I look at the 4.4s for sale from time to time but mine has been sorted for rust etc and I love it. Also I would think,for me, it is a bit cheaper to run. The mileage I do now doesn't make the fuel difference a big draw and spares for the 4.4 (suspension struts for example) can be quite a bit dearer.
16th Jan 2025 1:46pm |
