Home > Technical (L322) > Front LED Indicators in Headlights not working correctly
Giffer2018
United Kingdom 2011 Range Rover Vogue TDV8 Galway Green
Hi Guys,
Before Xmas my OSF LED indicator in the headlight started working intermittently, flashing a couple of times then nothing every time I turned right.
I checked the electrical connector to the headlight unit.
After that it has been working ok again, until yesterday. Now intermittent again.
Have any of you had this problem or know what the cause may be.
Thanks -----------------------
RR Vogue 4.4 TDV8 2011 - Galway Green
Kia Sorento 2.5 CDi 2007 - Bright Silver
Post #708654 8th Jan 2025 6:01pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
https://www.fullfatrr.com/forum/topic66925.html The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #708668 8th Jan 2025 8:25pm
GraemeS
Australia
The supply to the parker LEDs for both headlamps is PWM from a single wire from the BCM, with a solder joint for the split, then through a connector for each side (C2411/C2412 for LHS) nearly 2m of wire back from the headlamp connector. I suspect a poor connection at connector pair C2411/C2412 due to moisture and only a very small current ever passing through those terminals. Most of the wires at the headlamp connector pass through the connector pair so it might not be too difficult to find the connectors, although a connector location diagram would be very useful.
C2411/C2412 has at least 43 wires so is a major connector pair.
Post #708672 8th Jan 2025 9:07pm
Giffer2018
Thanks JMC for the interesting info. Problem is it’s the indicator so I cannot use a temporary supply like you.
I assume it is just a bad connection, so will have to find the fuses and relays as well.
Not looking forward to doing it in this weather! -----------------------
Post #708686 9th Jan 2025 11:29am
GraemeS
Australia
Pin 3 of the headlamp connector should have full 12V on and off at blinker speed. It powers a LED module inside the assembly. There isn't a fuse as it is switched on and off by a transistor (FET) in the central junction box.
Post #708688 9th Jan 2025 12:36pm
Giffer2018
GraemeS thanks for info. I will check when weather improves from -8C.
Did wonder if it may be the LED indicator module in headlamp that may need replacing or the bulb in the small side repeater, as the indicators will start working ok again even when I haven't touched anything. -----------------------
Post #708697 9th Jan 2025 3:50pm
GraemeS
Australia
The side repeaters are powered by their respective door modules, which seems very strange but it goes a long way towards explaining why my LED repeaters glow slightly after a door is opened until the vehicle goes back to sleep. Were side repeaters added as an after-thought, possibly not provided on the early L322s?
Post #708737 9th Jan 2025 8:59pm
Giffer2018
GraemeS, found what I think is terminal 3 in the connector plug.
It reads around 5 volts when the indicators are turned off and reads around 11/12 volts in time with the rest of the hazard lights flashing on and off.
So it looks like I am getting power to the headlight assembly, so would assume that it is a faulty LED indicator module which is screwed to the headlight unit.
Only problem is I cannot find out which one, as there are 3 screwed to the back of the headlamp unit.
Price of a new one from the dealers is crazy money, so it will have to be a second hand one. -----------------------
Post #708864 11th Jan 2025 4:49pm
GraemeS
Australia
Check the voltage at the same pin in the other headlight socket. It should be 12V, not 5V.
The LH wire is blue with green stripe and the RH yellow with purple stripe.
https://www.fullfatrr.com/gallery/albums/u...0HID~0.pdf
Post #708885 11th Jan 2025 8:28pm
Giffer2018
Having not had time to do any more investigating.
I had to take the RR for it's annual MOT test today, dreading it would fail on the OSF indicators.
Guess What, from starting it up, driving it there and all the time through the test, it worked perfectly.
This is the most unpredictable and frustrating vehicle at times, I have owned.
But I would not sell it. -----------------------
Post #709121 14th Jan 2025 6:02pm
