Home > General (L460 2022) > Detachable towbar
RRTIM
United Kingdom 2017 Range Rover Vogue SE SDV8 Causeway Grey
Detachable towbar
Has anybody had an aftermarket detachable towbar fitted to their L460?
Is so, is the bumper cut acceptable, or does it look pants?!
Thanks![/list] 2017 Range Rover SDV8 Vogue SE
2018 Audi RS6
2018 VW Amarok V6 255
Post #708548 7th Jan 2025 4:17pm
AndyS
I’ve had a non genuine detachable bar fitted to mine and there are no cuts to the removable cover unless like me, you want to keep the bar on for an extended time. I’ve bought another slightly damaged used cover off flea bay. You can just remove cover and use that way but looks a bit of a mess.
I’ve cut a hole out of the cover to enable the bar to remain fixed and looking tidy and once finished with I’ll just pop the original cover on.
Except that….I cut the whole in the wrong undamaged cover doh 😖😖🤓 Current fleet:
2020 McLaren 600LT Spider
2020 Mercedes C300 Cabriolet
2023 L460 PHEV 440 SE
1992 Lotus Esprit turbo
2019 Alpine A110 (French rubbish now gone)
Post #708653 8th Jan 2025 5:56pm
