Home > In Car Electronics (L322) > Front electric seats / steering column not woring
ScottR
United Kingdom 2008 Range Rover Vogue SE TDV8 Santorini Black
Good afternoon.
Looking to see if anyone can offer any help....
2008 Range Rover TDV8 Vogue SE front electric seats & steering wheel adjustment have suddenly stopped working.
Found alternator was faulty so replaced with one off the bay but it was constantly fluctuation between 12.5-15.7v & headlight, tail lights dash lights started strobing. Removed the ebay alternator & replaced with a brand new delco alternator.
Turned out the faulty one fried the LCM so found a replacement, fitted, all good.
However the front electric seats & steering column adjustment which were working previously have also stopped working.
Furthermore, i noticed the cruise control now no longer works either!
Checked all related fuses in fusebox which are fine.
Checked the main fuse input & there is no power actually getting to the fuse.
Has anyone else experienced this issue / can tell me what the likely problem is?
Seen on other forums people mention fuses under the seats but i have spare front seat, have checked & there are no fuses on them, just about half a dozen multiplugs.
As mentioned above, the seats / steering column were working fine before the unbranded alternator from the bay blew my LCM, im guessing due to constant undercharging / overcharging.
Thanks in advance.
Post #708261 4th Jan 2025 2:42pm
