![]() | Home > In Car Electronics (L322) > L322 Head Unit - Decent SAT NAV |
Steveg Member Since: 06 Apr 2024 Location: Norfolk Posts: 47 ![]() ![]() ![]() |
Yes, it comes complete with a frame. You attach the two end trim pieces to the frame and then screw back into existing fixing points. |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 ![]() ![]() |
Thank you for that.
Rincewind Member Since: 14 Jan 2025 Location: Cambridge Posts: 11 ![]() ![]() ![]() |
I seem to be in the same situation as Madnessgonemad, looking to upgrade the headunit on an HD sound car. Is anyone able to confirm that the Aoonav system is effectively plug and play on a 2011 HD sound system car and retains access to the car system and utilises the full HD sound capability.
With reference to your concerns about the HD system; apparently when you order from Ali Express they take careful note of your model and spec and provide the relevant cabling. It is different with the HD system but not over complicated.
