How To switch Transport Mode with P.A.Soft BMW Scanner 1.4 | |
Buy a cheap P.A.Soft BMW Scanner v1.4.0 package. ~US$20. This is a multi OBDII interface with a USB cable and a mini CD with software.
Do NOT plug this into the laptop until all of the software has been installed.
Install the software (from a reliable source, not the included CD) onto a laptop PC running a version of Windows.
[If your laptop is powerful enough you can install Windows as a 'virtual' environment on top of most operating systems]
If the FTDI drivers auto install, use Control Panel | Device Manager | Ports to uninstall them.
Install the correct USB drivers for your Windows version (direct from the FTDI site).
Plug in the scanner AFTER the correct drivers are installed. Start the BMW Scanner program.
Note that the program startup splash screen will report whether the correct drivers are installed or not, but the program can NOT be run and tested unless the OBDII scanner is connected to an OBDII plug in a vehicle !
Connect a charger to a vehicle's battery (unless you are only doing a single, quick reset).
If your scanner has a mode switch set it to 'K bus' mode - NOT 'D-CAN'. [1996 to 2005 BMWs connect via 'K-Line', later ones use Contoller Area Network - 'CAN', current ones use 'Ethernet']
Plug the cable into a vehicle. An LED will light to indicate that battery power is On.
Turn the key to position 2 = Run (do not crank or start the engine). This heavy battery drain is why a charger is needed. (A flat battery is probably what triggered the problem in the first place ...)
Start the program. An LED will flicker if communication is successful.
By default it will run a vehicle identity check first. The information is for display only, the program does NOT check what model the vehicle is (so it will work for BMW, Mini, Range Rover and Rolls Royce too).
Annoyingly all the program's windows overlay each other, so scan the info, then move or delete that 'Information about car' window.
From the buttons at the left of the main window select 'Page 1' of modules. Look for A/C or ZKE on page 1.
Double click the row that starts with A/C or ZKE to access the module's data.
Wait while the module is read.
If the module reports any errors (near top, left of the 'Unit' window) click on the 'Errors ...' button.
If the module is in Transport or Energy Saving Mode, click on the 'Reprogramming' button.
When the 'Used module reprogramming' window pops up it will list the various modes that apply to the module. Click on 'Normal'.
When the module's next startup mode has been set to 'normal' then 'Close' will change from grey to black. Click it.
Congratulations, you are half way there. Some 'normal' functions have been immediately restored, but others will require a restart of the module.
Close the module's window.
Exit the program.
Turn off the ignition.
Wait for the electronics to go to sleep. Have a coffee.
The module will now wake up in full 'normal' mode.
Congratulations, you are almost there.
Unfortunately a return to 'Normal' resets all comfort and convenience choices to their defaults.
However BMW Scanner can 'Code' all these features to whatever you want.
[Link to ALL instructions in next post]
Normal, OBDII fault code clearing -
Move or delete the 'Information about car' window.
Click on 'Scan!'. This will take a few minutes to test every module.
Double click on each line that has errors. Note, there are 3 pages to look at.
Click on 'Errors ...'
Click on 'Clear errors'. (Takes ~10s per error)
Repeat till all errors are cleared (or not). Any that won't clear need a hardware redress.
Exit the program.
My next post contains software /installation information.
bye 2003 TD6, EGR delete, vortex crankcase breather update, performance chip, UHF 2 way, Android head unit, crash camera on dash, always-on rear view camera to mirror screen, LED DRL`s, Electric trailer brake controller. FSR replaced. Pulling 3T caravan all about Australia
