Home > Maintenance & Mods (L405) > Reminder to check your sunroof drains |
qwerty Member Since: 21 Oct 2015 Location: Bristol Posts: 59 |
No problem hope my theory is right |
2nd Jan 2025 1:06pm |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 |
I just spent 1/2hr trying to find an answer to this online and failed miserably.
2nd Jan 2025 1:50pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1530 |
I can confirm, (unfortunately without the possibility of a proper :gloat: emoji) that the fixed panoramic roof is a single, bonded panel without any requirement for roof drains, (similar to the windscreen), this is shown in the WM in the Wiki above: |
2nd Jan 2025 2:52pm |
I am now anticipating a rush on the breakers’ yards, as folks clamour to retrofit fixed panoramic roofs “If it ain’t broke, don’t fix it” -where’s the fun in that? |
2nd Jan 2025 2:57pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1433 |
Afternoon Gremlin500
2nd Jan 2025 3:14pm |
It's a thought Gremlin, but only if the hole in the bodyshell is identical on cars originally fitted with fixed and opening panels.
2nd Jan 2025 3:18pm |
@DrF:
2nd Jan 2025 3:34pm |
Gremlin, don't get me wrong, I'm grateful like I'm sure many others are for you pointing out this shortcoming of the opening roof cars.
2nd Jan 2025 7:22pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1246 |
From Topix for my MY18 opening panoramic roof I get this in the manual, so I guess each build gets the same frame but different panel assembly so would presume the drains are there but not used unless the bonding material fails? No way of knowing unless you look inside the c pillar trim?
2nd Jan 2025 7:53pm |
See below
2nd Jan 2025 8:01pm |
While I was lurking and just now bought something from AllieEx, I added said Gremlin500 tickling stick for use on a warm sunny day 2018 SE SDV8 4.4 Byron Blue |
2nd Jan 2025 11:02pm |
Anyone have any idea about drains at the front as per my posts above? |
2nd Jan 2025 11:27pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
Although I am not being complacent about sunroof drains, I will have them, but there is a lot of discussion about said drains and hence a lot of posts. But have many people actually had a problem I have enough things to worry about and as Nasher asks, is it a BIG issue. Geoff |
3rd Jan 2025 12:32am |
Geoff. I need to clarify that I'm not asking if it's a big issue numbers wise, it appears that it's affecting too many otherwise good L405s.
3rd Jan 2025 9:19am |
