Home > Technical (L322) > What would be the cause of this type of damage!?
GFWC
United Kingdom 2010 Range Rover Vogue SE TDV8 Java Black
Hey guys, I’ve attached a photo of the damage to the rocker cover so you can jump straight to that and tell me if you’ve seen a melted one before. I’ll try and make the story really brief. Range ran perfectly a year ago, and then one night driving back, lost all power, was Smokey and ran like dog poop.
Garage had it, found damaged rocker cover, changed it, still ran Censored .
Found that the turbo actuator had seized, tried and tried to free it off and couldn’t, so new turbo.
Got them to replace the turbo, and the rocker cover needed doing again because it failed in the same spot.
They replaced the turbo, but car still runs like Censored , they suspected injector problem because of the damage to the rocker cover in the same spot. Changed injector. Same issue. Car ran like poop and failed another rocker cover.
Anyway, here is a picture of the rocker cover damage. The car has been off the road for a year now because nobody can fix it, it seems. Two garages had a go, they said they suspect valve damage.
A year on I’ve given it to someone else to inspect, he’s had the rocker cover off etc to check for valve damage and he said valves all seem good.
What could be possible causes of this type of damage to the rocker cover?
Thank you all so much
Car is a 3.6 TDV8 vogue se 120k miles
Post #707624 26th Dec 2024 8:31am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Photo? 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #707625 26th Dec 2024 8:43am
GFWC
sorry! messed up the whole upload process, its there now Smile thank you
Post #707627 26th Dec 2024 8:49am
JayGee
Difficult to see where it is in relation to the rest of the engine components but looks like heat damage to me. 2012 TDV8 Vogue (L322)
Post #707643 26th Dec 2024 3:08pm
fisha
Need some more pictures to be honest to show where and what else is around it. V8 or else ...
Post #707646 26th Dec 2024 6:20pm
p38arover
Australia
Rats? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #707655 27th Dec 2024 2:05am
