Home > Technical (L322) > L322 - AJV8 4.4 - ZF 6HP - Clutch Temperture Too High |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
That is a strange one. The transmission doesn’t contain any sensors that directly measure the clutch temperatures, only one for measuring the bulk oil temperature in the sump. This is located in the electronic module of the Mechatronic unit and, in your case, appears to be functioning correctly (reading 67°C). The controller must use some algorithm to predict clutch pack temperature based on its slip speed, solenoid current (clutch application pressure) and bulk oil temperature.
23rd Dec 2024 6:03pm |
JDenson998 Member Since: 23 Dec 2024 Location: North Wales Posts: 3 |
Hi RRPhil!
23rd Dec 2024 7:35pm |
Hi RRPhil!
23rd Dec 2024 8:02pm |
